Philco 41-290
Here's the Lowe's switch I was referring to.
https://www.lowes.com/pd/SERVALITE-Switc...ch/3379526
and an alternative, cheaper:
https://www.lowes.com/pd/Gardner-Bender-...ch/3379468
Philco 41-290 - by verb - 01-02-2018, 08:11 PM
RE: Philco 41-290 - by KCMike - 01-02-2018, 08:58 PM
RE: Philco 41-290 - by klondike98 - 01-02-2018, 09:17 PM
RE: Philco 41-290 - by Radioroslyn - 01-02-2018, 11:08 PM
RE: Philco 41-290 - by verb - 01-02-2018, 11:54 PM
RE: Philco 41-290 - by verb - 01-05-2018, 03:52 PM
RE: Philco 41-290 - by Raleigh - 01-16-2018, 05:08 PM
RE: Philco 41-290 - by Ron Ramirez - 01-16-2018, 08:53 PM
RE: Philco 41-290 - by verb - 01-16-2018, 10:25 PM
RE: Philco 41-290 - by verb - 01-16-2018, 10:26 PM
RE: Philco 41-290 - by verb - 04-06-2018, 05:55 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4934 online users. [Complete List]
» 2 Member(s) | 4932 Guest(s)
