7050 tube tester
Sometimes testers do that when the rectifier tube(s) panels' contacts need cleaning.
Mine does.
7050 tube tester - by brownie45 - 01-17-2018, 09:06 AM
RE: 7050 tube tester - by morzh - 01-17-2018, 09:08 AM
RE: 7050 tube tester - by klondike98 - 01-17-2018, 10:12 AM
There are currently 9439 online users. [Complete List]
» 1 Member(s) | 9438 Guest(s)
