Quad 8 track output?
I have a few stand alone 8t decks but i would like to install this one to play my 8 tracks and quad tapes, as you say, 8 track decks are everywhere but stand alone quad decks like this one, not so much.
Quad 8 track output? - by tab10672 - 01-17-2018, 05:08 PM
RE: Quad 8 track output? - by Arran - 01-18-2018, 02:27 AM
RE: Quad 8 track output? - by tab10672 - 01-18-2018, 12:17 PM
RE: Quad 8 track output? - by Ron Ramirez - 01-18-2018, 01:35 PM
RE: Quad 8 track output? - by Stall-U-Rated - 01-18-2018, 08:59 PM
RE: Quad 8 track output? - by Arran - 01-19-2018, 02:38 AM
RE: Quad 8 track output? - by jerryhawthorne - 01-19-2018, 07:37 PM
RE: Quad 8 track output? - by tab10672 - 01-20-2018, 12:27 AM
