Balelite block 3793-AM
If you are sure where the cap was connected (if the soldering looks factory), and the soldering of the lugs seems authentic, then why even question it: just put a new cap inside the same way it is now, and connect appropriately.
Balelite block 3793-AM - by Backtothefutureradios - 01-18-2018, 02:58 PM
RE: Balelite block 3793-AM - by morzh - 01-18-2018, 03:24 PM
RE: Balelite block 3793-AM - by klondike98 - 01-18-2018, 03:39 PM
RE: Balelite block 3793-AM - by Kestas - 01-18-2018, 06:02 PM
RE: Balelite block 3793-AM - by jcassity - 01-18-2018, 09:33 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6257 online users. [Complete List]
» 1 Member(s) | 6256 Guest(s)
