Next project: Western Air Patrol
They do seem rare, and the trail I found on the brand suggests sets commissioned from several manufacturers, rather than being a radio "house" in their own right. Parent company seems to have been based in Los Angeles, where we obtained the set. Google reveals some spectacular consoles.
This one has modern styling for the time (if I am correct about that). It also has a push pull output stage, magic eye indicator and good sized power transformer. On that basis, not a bargain basement design, but good quality. I will check the valve lineup later.
Next project: Western Air Patrol - by EdHolland - 01-18-2018, 05:28 PM
RE: Next project: Western Air Patrol - by morzh - 01-18-2018, 05:31 PM
RE: Next project: Western Air Patrol - by EdHolland - 01-18-2018, 07:12 PM
RE: Next project: Western Air Patrol - by morzh - 01-18-2018, 11:55 PM
RE: Next project: Western Air Patrol - by Arran - 01-19-2018, 12:52 AM
RE: Next project: Western Air Patrol - by SteveG - 01-19-2018, 07:14 PM
RE: Next project: Western Air Patrol - by Arran - 01-23-2018, 01:11 AM
RE: Next project: Western Air Patrol - by David - 01-25-2018, 09:48 PM
RE: Next project: Western Air Patrol - by KCMike - 04-05-2020, 04:56 PM
RE: Next project: Western Air Patrol - by RodB - 04-20-2020, 08:51 PM
RE: Next project: Western Air Patrol - by RodB - 04-21-2020, 09:54 AM
RE: Next project: Western Air Patrol - by 462ron - 04-24-2020, 07:48 AM
RE: Next project: Western Air Patrol - by 462ron - 04-26-2020, 08:47 AM
Philco 91 Tuning Condenser
