Philco 90
Yeah, no K voltage leads to the power resistor, but what voltage comes into the resistor? taps 4 & 12 off the transformer have nothing seem to be grounded, at least leads to the antenna ground.
Philco 90 - by lasurveyor - 01-18-2018, 01:26 PM
RE: Philco 90 - by morzh - 01-18-2018, 02:35 PM
RE: Philco 90 - by lasurveyor - 01-18-2018, 05:46 PM
RE: Philco 90 - by morzh - 01-18-2018, 06:27 PM
RE: Philco 90 - by lasurveyor - 01-18-2018, 08:04 PM
RE: Philco 90 - by morzh - 01-18-2018, 11:53 PM
RE: Philco 90 - by lasurveyor - 01-23-2018, 01:46 PM
RE: Philco 90 - by morzh - 01-23-2018, 02:14 PM
RE: Philco 90 - by Brad Winder - 01-24-2018, 02:35 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6243 online users. [Complete List]
» 1 Member(s) | 6242 Guest(s)
