6L6G vs 6L6GA
I'm frankly surprised the 6L6G isn't in your manual for the reasons I mentioned in my previous post (used in 38-116, 38-690, 42-1015 and 42-1016).
You may sub the 6L6G with 6L6GA, 6L6GB, 6L6GC. Also 6L6WGC, 5881, or 7581 (the 7581 is equivalent to a 6L6GB; the 7581A is equivalent to a 6L6GC).
The KT66 has a higher filament current (1.27A) than the 6L6 series (0.9A).
The 6L6G has the largest envelope. 6L6GA is also taper-top or "Coke bottle" shaped but smaller than 6L6G. Starting with 6L6GB, the envelope became tubular, tapered at the bottom just above the base.
6L6G vs 6L6GA - by WyTex - 01-17-2018, 03:25 PM
RE: 6L6G vs 6L6GA - by morzh - 01-17-2018, 03:41 PM
RE: 6L6G vs 6L6GA - by Radioroslyn - 01-17-2018, 04:01 PM
RE: 6L6G vs 6L6GA - by jcassity - 01-17-2018, 05:35 PM
RE: 6L6G vs 6L6GA - by Arran - 01-18-2018, 02:34 AM
RE: 6L6G vs 6L6GA - by WyTex - 01-18-2018, 06:45 AM
RE: 6L6G vs 6L6GA - by Arran - 01-19-2018, 12:49 AM
RE: 6L6G vs 6L6GA - by Ron Ramirez - 01-19-2018, 07:10 AM
RE: 6L6G vs 6L6GA - by WyTex - 01-19-2018, 12:36 PM
RE: 6L6G vs 6L6GA - by WyTex - 01-19-2018, 12:45 PM
RE: 6L6G vs 6L6GA - by Ron Ramirez - 01-19-2018, 01:36 PM
RE: 6L6G vs 6L6GA - by David - 01-19-2018, 03:51 PM
RE: 6L6G vs 6L6GA - by WyTex - 01-19-2018, 04:54 PM
RE: 6L6G vs 6L6GA - by Ron Ramirez - 01-19-2018, 07:07 PM
RE: 6L6G vs 6L6GA - by WyTex - 01-21-2018, 05:21 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6049 online users. [Complete List]
» 1 Member(s) | 6048 Guest(s)
