Is there an AC version similar to a 37-624?
Hi,
I am in the process of restoring a 37-624 and working on the vibrator power supply. Did you restuff the .5uf metal case caps (#s 72, 75, &76) and what did you use?
I need info on voltage rating of the caps. If you didn't restuff them, did you just replace them with orange drops or something like them. Any help from anyone reading this is appreciated.
I hope this is in the right place as I am new to this.
Gerald Daniel
The speaker table error?
Philco 70 antenna lead
There are currently 6837 online users. [Complete List]
» 2 Member(s) | 6835 Guest(s)
