4 position tone control 90X
Fran
I have rebuilt several Philco radios that use this or very similar type of Tone control, including 90 and 70 models.
This is the first time I hear about this defect having occurred. The effort of the sliding contact moving across the contacts' caps is very light.
Well, in the worst case for a while you will have to operate the radio without the tone control, it will just work at the peak of the treble transfer; when you locate the new control or fix this, you could install it.
4 position tone control 90X - by patrician56 - 01-21-2018, 12:11 PM
RE: 4 position tone control 90X - by morzh - 01-22-2018, 09:25 AM
RE: 4 position tone control 90X - by patrician56 - 01-22-2018, 10:57 AM
RE: 4 position tone control 90X - by Radioroslyn - 01-22-2018, 11:52 AM
RE: 4 position tone control 90X - by patrician56 - 01-22-2018, 10:18 PM
RE: 4 position tone control 90X - by Arran - 01-23-2018, 01:26 AM
RE: 4 position tone control 90X - by Phlogiston - 01-23-2018, 12:35 PM
RE: 4 position tone control 90X - by EdHolland - 01-23-2018, 01:28 PM
RE: 4 position tone control 90X - by patrician56 - 01-23-2018, 03:57 PM
RE: 4 position tone control 90X - by patrician56 - 01-23-2018, 04:02 PM
RE: 4 position tone control 90X - by patrician56 - 01-23-2018, 04:04 PM
RE: 4 position tone control 90X - by EdHolland - 01-26-2018, 03:03 PM
RE: 4 position tone control 90X - by Arran - 01-27-2018, 12:53 AM
RE: 4 position tone control 90X - by patrician56 - 01-28-2018, 09:19 PM
RE: 4 position tone control 90X - by EdHolland - 01-28-2018, 09:25 PM
RE: 4 position tone control 90X - by patrician56 - 01-28-2018, 09:33 PM
RE: 4 position tone control 90X - by EdHolland - 01-29-2018, 12:12 AM
RE: 4 position tone control 90X - by patrician56 - 01-29-2018, 10:05 AM
The speaker table error?
Philco 70 antenna lead
