37 and 38 690 Grill cloth
It is strange that in the 116 versions they used the chevron pattern and in the 690 - ribbed.
Mine is intact, and I saw others in photos....I even thought at some point, before I got mine, that the 690 had some replacement cloth, I was so sure there should've been chevron. And it would look good too!
37 and 38 690 Grill cloth - by Skip - 01-21-2018, 11:14 PM
RE: 37 and 38 690 Grill cloth - by Ron Ramirez - 01-22-2018, 07:06 AM
RE: 37 and 38 690 Grill cloth - by morzh - 01-22-2018, 09:28 AM
RE: 37 and 38 690 Grill cloth - by Skip - 01-25-2018, 02:32 AM
