Philco 18 volume pot cleaning??
sorry,
misread the part where the switch HAS been cleaned and the carbon part is being cleaned.
Yes, what Russ said. Deoxit Green, fader lube.
Philco 18 volume pot cleaning?? - by jeffb - 01-22-2018, 11:27 AM
RE: Philco 18 volume pot cleaning?? - by morzh - 01-22-2018, 11:34 AM
RE: Philco 18 volume pot cleaning?? - by jeffb - 01-22-2018, 01:43 PM
RE: Philco 18 volume pot cleaning?? - by morzh - 01-22-2018, 02:29 PM
The speaker table error?
Philco 70 antenna lead
