Philco 90
Thanks for pointing me to the field coil. I did have a pin problem with the 47 complicating things with intermittent function, and now I'm convinced that the field coil is open. The radio is dead until I short the field coil, then it comes alive. Of course I then have over a hundred volts on the screen grids. I have a 1930 Dayfan speaker that I am able to fire up including the field coil, while I can't get any magnification out of the Philco speaker. I do get a small amount of sound out of the Philco without the field coil. I see speakers for sale often emphasize "working field coil". Is it common for these to open?
Looks like an expensive fix but I'm into this so deep I have to do something. Either a loner radio or a salvaged speaker? Does anyone repair these?
Alan
Philco 90 - by lasurveyor - 01-18-2018, 01:26 PM
RE: Philco 90 - by morzh - 01-18-2018, 02:35 PM
RE: Philco 90 - by lasurveyor - 01-18-2018, 05:46 PM
RE: Philco 90 - by morzh - 01-18-2018, 06:27 PM
RE: Philco 90 - by lasurveyor - 01-18-2018, 08:04 PM
RE: Philco 90 - by morzh - 01-18-2018, 11:53 PM
RE: Philco 90 - by lasurveyor - 01-23-2018, 01:46 PM
RE: Philco 90 - by morzh - 01-23-2018, 02:14 PM
RE: Philco 90 - by Brad Winder - 01-24-2018, 02:35 AM
The speaker table error?
Philco 70 antenna lead
There are currently 5973 online users. [Complete List]
» 1 Member(s) | 5972 Guest(s)
