EL84 amplifier
I'm not certain about what you are asking, if you are asking whether you can convert this single ended amplifier and power supply into a stereo amp then the answer is maybe. The question is whether there was anything else attached to this unit, if it had a tuner chassis plugged into, and powered off of it then you might be able to use that transformer to power a duplicate amplifier for the other stereo channel. However if this was just a single ended amp from a phonograph unit then it's really just a guess as to whether the power supply would be enough. Where was the EZ80 tube located, I see two tubes in two sockets, and a third in the end with nothing in it? Where are the controls, like the power switch, volume control, etc? Do you have a schematic for this unit?
EL84 amplifier - by ftovar72 - 01-25-2018, 10:47 AM
RE: EL84 amplifier - by codefox1 - 01-25-2018, 09:29 PM
RE: EL84 amplifier - by ftovar72 - 01-25-2018, 10:52 PM
RE: EL84 amplifier - by Arran - 01-25-2018, 11:56 PM
RE: EL84 amplifier - by ftovar72 - 01-26-2018, 10:11 AM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4828 online users. [Complete List]
» 3 Member(s) | 4825 Guest(s)
