philco wire wound resistor values
Where can I find resistance values for part number 4953 wire wound resistor in model 90a double 45 tubes
thanks Martin
philco wire wound resistor values - by nitram11 - 01-26-2018, 09:31 PM
The speaker table error?
Philco 70 antenna lead
There are currently 3222 online users. [Complete List]
» 2 Member(s) | 3220 Guest(s)
