philco wire wound resistor values
Thank you for your quick reply and now we can finish the radio up
Martin
philco wire wound resistor values - by nitram11 - 01-26-2018, 09:31 PM
RE: philco wire wound resistor values - by nitram11 - 01-27-2018, 12:47 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5897 online users. [Complete List]
» 1 Member(s) | 5896 Guest(s)
