audio woes on the 38-5
Yes, it is pointing to a possible bad connection.
Take a plastic stick and poke around. Clean the sockets, rock the tubes.....the usual.
audio woes on the 38-5 - by NostalgiaRadioTime - 01-24-2018, 11:30 PM
RE: audio woes on the 38-5 - by morzh - 01-24-2018, 11:56 PM
RE: audio woes on the 38-5 - by Radioroslyn - 01-26-2018, 01:15 PM
RE: audio woes on the 38-5 - by morzh - 01-26-2018, 02:41 PM
RE: audio woes on the 38-5 - by Ron Ramirez - 01-27-2018, 12:12 AM
RE: audio woes on the 38-5 - by Radioroslyn - 01-27-2018, 12:49 AM
RE: audio woes on the 38-5 - by morzh - 01-28-2018, 10:53 AM
RE: audio woes on the 38-5 - by Steve Chambers - 01-28-2018, 11:14 AM
The speaker table error?
Philco 70 antenna lead
