audio woes on the 38-5
Could be a loose or bad connection. Could also be a bad or weak 6A8 tube that refuses to oscillate or works intermittently. As suggested earlier in the thread have you tried listening for the oscillator signal on a known good radio that’s nearby?
Steve Chambers
audio woes on the 38-5 - by NostalgiaRadioTime - 01-24-2018, 11:30 PM
RE: audio woes on the 38-5 - by morzh - 01-24-2018, 11:56 PM
RE: audio woes on the 38-5 - by Radioroslyn - 01-26-2018, 01:15 PM
RE: audio woes on the 38-5 - by morzh - 01-26-2018, 02:41 PM
RE: audio woes on the 38-5 - by Ron Ramirez - 01-27-2018, 12:12 AM
RE: audio woes on the 38-5 - by Radioroslyn - 01-27-2018, 12:49 AM
RE: audio woes on the 38-5 - by morzh - 01-28-2018, 10:53 AM
RE: audio woes on the 38-5 - by Steve Chambers - 01-28-2018, 11:14 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6766 online users. [Complete List]
» 2 Member(s) | 6764 Guest(s)
