4 position tone control 90X
Fran,
I dug out the switch just now and took a couple of pictures. It is in good mechanical shape. Caps are original to the 5 band model 16 from which it came.
If this works for your radio, let me know and it is yours.
Cheers
Ed
4 position tone control 90X - by patrician56 - 01-21-2018, 12:11 PM
RE: 4 position tone control 90X - by morzh - 01-22-2018, 09:25 AM
RE: 4 position tone control 90X - by patrician56 - 01-22-2018, 10:57 AM
RE: 4 position tone control 90X - by Radioroslyn - 01-22-2018, 11:52 AM
RE: 4 position tone control 90X - by patrician56 - 01-22-2018, 10:18 PM
RE: 4 position tone control 90X - by Arran - 01-23-2018, 01:26 AM
RE: 4 position tone control 90X - by Phlogiston - 01-23-2018, 12:35 PM
RE: 4 position tone control 90X - by EdHolland - 01-23-2018, 01:28 PM
RE: 4 position tone control 90X - by patrician56 - 01-23-2018, 03:57 PM
RE: 4 position tone control 90X - by patrician56 - 01-23-2018, 04:02 PM
RE: 4 position tone control 90X - by patrician56 - 01-23-2018, 04:04 PM
RE: 4 position tone control 90X - by EdHolland - 01-26-2018, 03:03 PM
RE: 4 position tone control 90X - by Arran - 01-27-2018, 12:53 AM
RE: 4 position tone control 90X - by patrician56 - 01-28-2018, 09:19 PM
RE: 4 position tone control 90X - by EdHolland - 01-28-2018, 09:25 PM
RE: 4 position tone control 90X - by patrician56 - 01-28-2018, 09:33 PM
RE: 4 position tone control 90X - by EdHolland - 01-29-2018, 12:12 AM
RE: 4 position tone control 90X - by patrician56 - 01-29-2018, 10:05 AM
The speaker table error?
Philco 70 antenna lead
There are currently 1831 online users. [Complete List]
» 2 Member(s) | 1829 Guest(s)
