Model 70
#43
Ok, Alignment complete.. No problems.. Bought a alignment tool on ebay .. It made the process very easy.. The IF 's were off quite a bit.. Radio now plays better than before.. Playing well now on bench.. So now to get the Cabinet repaired,,
Skip
Model 70 - by vecher - 11-29-2017, 09:41 PM
RE: Model 70 - by Ron Ramirez - 11-29-2017, 10:33 PM
RE: Model 70 - by vecher - 12-02-2017, 01:55 AM
RE: Model 70 - by Arran - 12-02-2017, 03:46 AM
RE: Model 70 - by Steve Davis - 12-02-2017, 08:53 AM
RE: Model 70 - by vecher - 12-02-2017, 02:30 PM
RE: Model 70 - by vecher - 12-02-2017, 04:40 PM
RE: Model 70 - by vecher - 12-03-2017, 11:23 AM
RE: Model 70 - by morzh - 12-03-2017, 12:20 PM
RE: Model 70 - by vecher - 12-25-2017, 12:40 AM
RE: Model 70 - by AudreyHepburn - 12-29-2017, 11:14 PM
RE: Model 70 - by vecher - 12-29-2017, 11:59 PM
RE: Model 70 - by Radioroslyn - 12-30-2017, 12:36 AM
RE: Model 70 - by TV MAN - 12-30-2017, 11:30 PM
RE: Model 70 - by vecher - 12-31-2017, 02:19 AM
RE: Model 70 - by vecher - 01-07-2018, 12:17 AM
RE: Model 70 - by klondike98 - 01-07-2018, 09:16 AM
RE: Model 70 - by Steve Davis - 01-07-2018, 10:46 AM
RE: Model 70 - by Ron Ramirez - 01-07-2018, 10:52 AM
RE: Model 70 - by vecher - 01-07-2018, 12:53 PM
RE: Model 70 - by vecher - 01-10-2018, 12:15 PM
RE: Model 70 - by Steve Davis - 01-10-2018, 12:36 PM
RE: Model 70 - by klondike98 - 01-10-2018, 01:07 PM
RE: Model 70 - by vecher - 01-10-2018, 02:08 PM
RE: Model 70 - by morzh - 01-10-2018, 05:05 PM
RE: Model 70 - by klondike98 - 01-10-2018, 06:25 PM
RE: Model 70 - by Warren - 01-10-2018, 09:17 PM
RE: Model 70 - by vecher - 01-11-2018, 12:59 AM
RE: Model 70 - by vecher - 01-11-2018, 01:12 AM
RE: Model 70 - by Steve Davis - 01-11-2018, 02:00 AM
RE: Model 70 - by morzh - 01-11-2018, 09:36 AM
RE: Model 70 - by vecher - 01-13-2018, 08:18 PM
RE: Model 70 - by vecher - 01-13-2018, 08:21 PM
RE: Model 70 - by vecher - 01-17-2018, 12:13 AM
RE: Model 70 - by vecher - 01-20-2018, 09:17 PM
RE: Model 70 - by Steve Davis - 01-21-2018, 12:07 AM
RE: Model 70 - by EdHolland - 01-21-2018, 03:33 AM
RE: Model 70 - by Steve D - 01-21-2018, 11:49 AM
RE: Model 70 - by vecher - 01-21-2018, 02:22 PM
RE: Model 70 - by vecher - 01-21-2018, 06:02 PM
RE: Model 70 - by vecher - 01-22-2018, 12:02 AM
RE: Model 70 - by vecher - 01-22-2018, 09:47 PM
RE: Model 70 - by vecher - 01-28-2018, 11:25 PM
RE: Model 70 - by mg34.42 - 03-18-2018, 03:32 PM
Users browsing this thread: 16 Guest(s)
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4549 online users. [Complete List]
» 2 Member(s) | 4547 Guest(s)
