Speaker circuit for the 38-7
Are you talking of the field coil?
All these early speakers used a DC electromagnetic coil instead of a Perm magnet.
The coil iften doubles as the rectifier filter.
Speaker circuit for the 38-7 - by cpollock - 01-28-2018, 10:35 PM
RE: Speaker circuit for the 38-7 - by morzh - 01-28-2018, 11:34 PM
RE: Speaker circuit for the 38-7 - by cpollock - 01-28-2018, 11:38 PM
RE: Speaker circuit for the 38-7 - by EdHolland - 01-29-2018, 12:02 AM
RE: Speaker circuit for the 38-7 - by morzh - 01-29-2018, 10:41 AM
RE: Speaker circuit for the 38-7 - by cpollock - 01-29-2018, 10:58 AM
The speaker table error?
Philco 70 antenna lead
