Speaker circuit for the 38-7
Thanks, I was wondering about that. It seemed ironic to be using the speaker magnet coil as a choke to reduce ripple for the B+ to reduce 120Hz hum on the sound, only to be sending that alternating current right to the speaker.
I am impressed by all the clever ideas that were developed to optimize these circuits.
Speaker circuit for the 38-7 - by cpollock - 01-28-2018, 10:35 PM
RE: Speaker circuit for the 38-7 - by morzh - 01-28-2018, 11:34 PM
RE: Speaker circuit for the 38-7 - by cpollock - 01-28-2018, 11:38 PM
RE: Speaker circuit for the 38-7 - by EdHolland - 01-29-2018, 12:02 AM
RE: Speaker circuit for the 38-7 - by morzh - 01-29-2018, 10:41 AM
RE: Speaker circuit for the 38-7 - by cpollock - 01-29-2018, 10:58 AM
The speaker table error?
Philco 70 antenna lead
