Philco 41-250 (a/k/a The "Flood" Radio)
Thanks very much. It was a very rewarding project considering what I started with.
For what this one went through, I also have to add that I didn't come across any open coils in it, not counting the damaged transformer, of course. Then again, this is not an every day radio, and I would imagine if I ran it more often than an hour or so every couple of months, it might be an issue at some point. Until then, I won't worry about it.
Again, thanks for the comments. They're very much appreciated.
Bill
Sent from my Pentium II on the AT&T Dial Network
[No subject] - by Ron Ramirez - 10-11-2005, 11:18 PM
[No subject] - by Jerry Huelsbeck - 10-12-2005, 03:09 PM
[No subject] - by Bill Hutchinson - 10-13-2005, 10:12 PM
[No subject] - by Chuck Schwark - 10-13-2005, 10:37 PM
