Black wooden feet for Zenith 6S222
From what research and pics . They are the same . looked at several pics perfect match . Icon_wink
Black wooden feet for Zenith 6S222 - by Steve D - 04-30-2010, 09:30 AM
Re: Black wooden feet for Zenith 6S222 - by denver - 04-30-2010, 02:07 PM
Philco 91 Tuning Condenser
