Mike Osc AM radio transmitter?
The sel rect will drop line voltage app 7 volts, the silicon diodes drop voltage 7/10 of a volt big difference. You can either use about 10 silicon diodes in series or a diode and a resistor. With the higher line voltages today I would use a couple of diodes and a resistor. Have done this on several Z sets and been happy with the out come. The reason for using more than one diode so if one fails the set still receives only dc.
Mike Osc AM radio transmitter? - by TV MAN - 01-29-2018, 06:57 PM
RE: Mike Osc AM radio transmitter? - by Arran - 01-30-2018, 05:52 AM
RE: Mike Osc AM radio transmitter? - by David - 02-01-2018, 10:29 AM
RE: Mike Osc AM radio transmitter? - by TV MAN - 02-01-2018, 04:03 PM
RE: Mike Osc AM radio transmitter? - by Arran - 02-01-2018, 11:04 PM
RE: Mike Osc AM radio transmitter? - by TV MAN - 02-15-2018, 12:35 PM
RE: Mike Osc AM radio transmitter? - by TV MAN - 02-15-2018, 12:55 PM
RE: Mike Osc AM radio transmitter? - by TV MAN - 02-15-2018, 11:43 PM
RE: Mike Osc AM radio transmitter? - by TV MAN - 02-17-2018, 07:37 PM
RE: Mike Osc AM radio transmitter? - by 35Z5 - 02-23-2018, 12:03 PM
RE: Mike Osc AM radio transmitter? - by TV MAN - 02-23-2018, 08:37 PM
RE: Mike Osc AM radio transmitter? - by 35Z5 - 02-23-2018, 10:28 PM
RE: Mike Osc AM radio transmitter? - by TV MAN - 02-24-2018, 03:05 PM
RE: Mike Osc AM radio transmitter? - by TV MAN - 02-24-2018, 07:01 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
