48 460 Restoration
Welcome!
You can find the Philco service bulletin here on AudioPhool: http://audiophool.com/Philco.html
There are also Riders service bulletins available from NostalgiaAir: http://www.nostalgiaair.org/Resources/634/M0013634.htm
The Riders bulletins are OK but often not as detailed. Also the scan quality is a bit better on AudioPhool but you'll need to convert from DJVU format to PDF for viewing.
I've attached the PDF for the 48-460.
According to the parts list the original speaker is part 36-1615.
Have you measured the original? If it's a physical match then I believe it should work fine since it's a permanent magnet speaker.
48 460 Restoration - by Bogey2300 - 02-02-2018, 12:12 PM
RE: 48 460 Restoration - by Nathan Slingerland - 02-02-2018, 12:43 PM
RE: 48 460 Restoration - by klondike98 - 02-02-2018, 01:32 PM
RE: 48 460 Restoration - by Bogey2300 - 02-02-2018, 01:48 PM
RE: 48 460 Restoration - by Bogey2300 - 02-04-2018, 11:42 AM
RE: 48 460 Restoration - by Nathan Slingerland - 02-04-2018, 11:56 AM
RE: 48 460 Restoration - by Nathan Slingerland - 02-04-2018, 11:59 AM
RE: 48 460 Restoration - by Bogey2300 - 02-04-2018, 12:16 PM
RE: 48 460 Restoration - by Radioroslyn - 02-04-2018, 01:30 PM
RE: 48 460 Restoration - by Electrothaumaturgist - 02-04-2018, 01:50 PM
RE: 48 460 Restoration - by Radioroslyn - 02-04-2018, 06:23 PM
RE: 48 460 Restoration - by Electrothaumaturgist - 02-04-2018, 08:52 PM
RE: 48 460 Restoration - by Bogey2300 - 02-08-2018, 02:03 PM
RE: 48 460 Restoration - by Nathan Slingerland - 02-08-2018, 02:41 PM
RE: 48 460 Restoration - by morzh - 02-08-2018, 04:25 PM
RE: 48 460 Restoration - by Bogey2300 - 02-08-2018, 04:27 PM
RE: 48 460 Restoration - by Bogey2300 - 02-12-2018, 10:47 AM
RE: 48 460 Restoration - by Tubeglow20 - 02-21-2020, 01:53 PM
There are currently 4405 online users. [Complete List]
» 3 Member(s) | 4402 Guest(s)
