37-624 Mail Filter Cap 34 is NON-POLARIZED
Thanks TBONE.
Restuffing with the 400 volt caps would have been a lot easier. I wasn't sure how much the start-up voltage would be and what the actual unloaded DC output of the vibrator supply would be. I probably done a little overkill and made extra work in reworking the C64 can that mounts next to the vibrator supply.
Gerald D.
RE: 37-624 Mail Filter Cap 34 is NON-POLARIZED - by harley92 - 02-03-2018, 09:07 PM
[No subject] - by Chuck Schwark - 02-25-2008, 09:28 PM
[No subject] - by davemc - 02-26-2008, 07:13 AM
[No subject] - by Ron Ramirez - 02-26-2008, 07:59 AM
[No subject] - by davemc - 02-26-2008, 08:13 AM
[No subject] - by Steve D - 02-26-2008, 12:38 PM
[No subject] - by davemc - 02-26-2008, 01:06 PM
[No subject] - by davemc - 03-03-2008, 06:07 PM
[No subject] - by Ron Ramirez - 03-03-2008, 11:10 PM
[No subject] - by davemc - 03-14-2008, 05:25 PM
[No subject] - by Ron Ramirez - 03-20-2008, 10:58 PM
The speaker table error?
Philco 70 antenna lead
