Philco 46-350
Hi,
After checking my 46-360 and diagrams from chuck I found that radio comes a little bit differences and looks like it was modified as an 48-360, so I followed the troubleshoot steps in 48-360 service documents. To test section 2 I used and old LG MP3 player as audio frequency signal generator
[Image: http://casamadriddev.com/philco/Troubleshooting.jpg]
When I check in Test Point A I get sound with a choppy noise in the background, this sound maintains the same volume.
When I check in Test Point C I get clear music in speaker.
When I check in Testp Point D I get music with choppy speaker sound.
I am not sure if choppy sound (click) comes from C200 becasue in C point I dont get it in speaker, any thoughts ?
Also I noticed something on Z300 component with PN P32-3970 when radio is on I can see something inside that lights in red I am not sure if that is ok
any thoughts ?
Regards!
Francisco Tovar
Frank Tovar
Philco 46-350 - by ftovar72 - 10-09-2017, 12:00 AM
RE: [split] Philco 46-350 - by sam - 10-09-2017, 12:24 AM
RE: [split] Philco 46-350 - by Radioroslyn - 10-09-2017, 12:31 AM
RE: Philco 46-350 - by ftovar72 - 10-09-2017, 08:51 PM
RE: Philco 46-350 - by Radioroslyn - 10-09-2017, 10:28 PM
RE: Philco 46-350 - by Raleigh - 10-10-2017, 10:01 AM
RE: Philco 46-350 - by ftovar72 - 10-10-2017, 12:11 PM
RE: Philco 46-350 - by Raleigh - 10-10-2017, 01:18 PM
RE: Philco 46-350 - by ftovar72 - 10-10-2017, 11:55 PM
RE: Philco 46-350 - by Raleigh - 10-11-2017, 09:56 AM
RE: Philco 46-350 - by ftovar72 - 10-12-2017, 06:12 PM
RE: Philco 46-350 - by David - 10-12-2017, 06:50 PM
RE: Philco 46-350 - by ftovar72 - 10-13-2017, 12:01 AM
RE: Philco 46-350 - by Raleigh - 10-14-2017, 08:53 AM
RE: Philco 46-350 - by ftovar72 - 10-14-2017, 08:58 AM
RE: Philco 46-350 - by ftovar72 - 10-18-2017, 10:02 PM
RE: Philco 46-350 - by ftovar72 - 01-08-2018, 12:03 AM
RE: Philco 46-350 - by Radioroslyn - 01-08-2018, 12:40 PM
RE: Philco 46-350 - by ftovar72 - 02-04-2018, 12:56 AM
RE: Philco 46-350 - by ftovar72 - 02-13-2018, 11:06 AM
RE: Philco 46-350 - by codefox1 - 02-14-2018, 04:58 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5988 online users. [Complete List]
» 1 Member(s) | 5987 Guest(s)
