model 18 no reception
Hi Terry   Now today the radio is a little off the dial by 30 kHz.  Yesterday it was right on.  I did the 2 radio test for the oscillator.  I could hear it up to 1030kc and the other radio was at 1250kc.  That's where it drops out.  Also checked voltage @pin 4 of 6A7 --  106.2 to grnd.    102 to K.  I hope this gives you an idea.  Also when I first turned the radio on I had to touch pin 5 of 6A7 to get reception.  Don't know if there is a bad connection in the socket or what.  Thanks
Dick
model 18 no reception - by madsowry - 02-02-2018, 12:03 AM
RE: model 18 no reception - by morzh - 02-02-2018, 09:14 AM
RE: model 18 no reception - by Radioroslyn - 02-02-2018, 10:04 AM
RE: model 18 no reception - by madsowry - 02-02-2018, 04:28 PM
RE: model 18 no reception - by morzh - 02-02-2018, 11:16 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 01:59 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 04:30 PM
RE: model 18 no reception - by Radioroslyn - 02-03-2018, 05:52 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 06:54 PM
RE: model 18 no reception - by morzh - 02-03-2018, 07:24 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 07:54 PM
RE: model 18 no reception - by morzh - 02-03-2018, 08:11 PM
RE: model 18 no reception - by madsowry - 02-04-2018, 12:08 AM
RE: model 18 no reception - by morzh - 02-04-2018, 10:51 AM
RE: model 18 no reception - by madsowry - 02-04-2018, 02:08 PM
RE: model 18 no reception - by Radioroslyn - 02-04-2018, 06:17 PM
RE: model 18 no reception - by madsowry - 02-04-2018, 06:34 PM
RE: model 18 no reception - by madsowry - 02-05-2018, 02:50 PM
RE: model 18 no reception - by Radioroslyn - 02-05-2018, 03:53 PM
RE: model 18 no reception - by madsowry - 02-05-2018, 08:11 PM
RE: model 18 no reception - by madsowry - 02-06-2018, 04:51 PM
RE: model 18 no reception - by morzh - 02-06-2018, 08:38 PM
RE: model 18 no reception - by madsowry - 02-07-2018, 12:01 AM
RE: model 18 no reception - by madsowry - 02-09-2018, 06:32 PM
RE: model 18 no reception - by Radioroslyn - 02-09-2018, 08:27 PM
RE: model 18 no reception - by madsowry - 02-09-2018, 09:59 PM
RE: model 18 no reception - by Radioroslyn - 02-10-2018, 10:37 AM
RE: model 18 no reception - by madsowry - 02-12-2018, 12:07 AM
RE: model 18 no reception - by Radioroslyn - 02-12-2018, 09:15 AM
RE: model 18 no reception - by madsowry - 02-23-2018, 01:00 AM
RE: model 18 no reception - by morzh - 02-23-2018, 08:53 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6372 online users. [Complete List]
» 1 Member(s) | 6371 Guest(s)
