model 18 no reception
Thanks Terry   I will rewind it and not that I know even what I'm doing I agree after the 2 radio test it has to be the oscillator coil.  I rewound it before using 40 gauge and 17 wraps.  So if I wrap 19 or 20 will that be sufficient or just play with it with jumpers until I get a full dial?  Thanks
Dick
model 18 no reception - by madsowry - 02-02-2018, 12:03 AM
RE: model 18 no reception - by morzh - 02-02-2018, 09:14 AM
RE: model 18 no reception - by Radioroslyn - 02-02-2018, 10:04 AM
RE: model 18 no reception - by madsowry - 02-02-2018, 04:28 PM
RE: model 18 no reception - by morzh - 02-02-2018, 11:16 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 01:59 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 04:30 PM
RE: model 18 no reception - by Radioroslyn - 02-03-2018, 05:52 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 06:54 PM
RE: model 18 no reception - by morzh - 02-03-2018, 07:24 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 07:54 PM
RE: model 18 no reception - by morzh - 02-03-2018, 08:11 PM
RE: model 18 no reception - by madsowry - 02-04-2018, 12:08 AM
RE: model 18 no reception - by morzh - 02-04-2018, 10:51 AM
RE: model 18 no reception - by madsowry - 02-04-2018, 02:08 PM
RE: model 18 no reception - by Radioroslyn - 02-04-2018, 06:17 PM
RE: model 18 no reception - by madsowry - 02-04-2018, 06:34 PM
RE: model 18 no reception - by madsowry - 02-05-2018, 02:50 PM
RE: model 18 no reception - by Radioroslyn - 02-05-2018, 03:53 PM
RE: model 18 no reception - by madsowry - 02-05-2018, 08:11 PM
RE: model 18 no reception - by madsowry - 02-06-2018, 04:51 PM
RE: model 18 no reception - by morzh - 02-06-2018, 08:38 PM
RE: model 18 no reception - by madsowry - 02-07-2018, 12:01 AM
RE: model 18 no reception - by madsowry - 02-09-2018, 06:32 PM
RE: model 18 no reception - by Radioroslyn - 02-09-2018, 08:27 PM
RE: model 18 no reception - by madsowry - 02-09-2018, 09:59 PM
RE: model 18 no reception - by Radioroslyn - 02-10-2018, 10:37 AM
RE: model 18 no reception - by madsowry - 02-12-2018, 12:07 AM
RE: model 18 no reception - by Radioroslyn - 02-12-2018, 09:15 AM
RE: model 18 no reception - by madsowry - 02-23-2018, 01:00 AM
RE: model 18 no reception - by morzh - 02-23-2018, 08:53 AM
The speaker table error?
Philco 70 antenna lead
