Nathan's 112 Highboy
Progress report!
Filter Can
After leaving the filter can in Evaporust overnight I retrieved it and rinsed it off:
[Image: https://farm5.staticflickr.com/4663/3999...c261_z.jpg] [Image: https://farm5.staticflickr.com/4745/2615...53c4_z.jpg]
It wasn't real rusty to begin with but the rust it had is gone. I mounted it back on the chassis.
Tone Control
Standard deal here.
[Image: https://farm5.staticflickr.com/4756/3931...1e6c_z.jpg] [Image: https://farm5.staticflickr.com/4609/3912...1ed9_z.jpg]
I removed the tar block and used a terminal to connect the replacement caps. I like this method because it's easy to work with and doesn't require any permanent modifications to mount.
[Image: https://farm5.staticflickr.com/4604/3931...91f8_z.jpg]
Other Stuff
Around the same time I rebuilt the other metal can capacitors.
Nathan's 112 Highboy - by Nathan Slingerland - 01-28-2018, 04:14 PM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 01-28-2018, 04:51 PM
RE: Nathan's 112 Highboy - by morzh - 01-28-2018, 05:11 PM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 01-28-2018, 11:08 PM
RE: Nathan's 112 Highboy - by gregb - 01-28-2018, 11:40 PM
RE: Nathan's 112 Highboy - by KCMike - 01-28-2018, 11:50 PM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 01-30-2018, 12:38 PM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 01-31-2018, 01:26 AM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 01-31-2018, 01:49 AM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 01-31-2018, 02:24 PM
RE: Nathan's 112 Highboy - by Kestas - 01-31-2018, 04:38 PM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 01-31-2018, 05:40 PM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 01-31-2018, 08:50 PM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 02-05-2018, 12:08 AM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 02-05-2018, 12:30 AM
RE: Nathan's 112 Highboy - by Radioroslyn - 02-05-2018, 11:45 AM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 02-05-2018, 12:01 PM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 02-08-2018, 01:02 AM
RE: Nathan's 112 Highboy - by Ron Ramirez - 02-08-2018, 06:54 AM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 02-08-2018, 07:41 AM
RE: Nathan's 112 Highboy - by Ron Ramirez - 02-08-2018, 11:02 AM
RE: Nathan's 112 Highboy - by Radioroslyn - 02-08-2018, 01:08 PM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 02-08-2018, 01:24 PM
RE: Nathan's 112 Highboy - by Steve Davis - 02-09-2018, 02:30 AM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 02-09-2018, 02:44 AM
RE: Nathan's 112 Highboy - by Radioroslyn - 02-09-2018, 11:01 AM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 02-19-2018, 09:17 PM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 02-19-2018, 09:20 PM
RE: Nathan's 112 Highboy - by morzh - 02-19-2018, 10:21 PM
RE: Nathan's 112 Highboy - by Nathan Slingerland - 02-19-2018, 10:31 PM
RE: Nathan's 112 Highboy - by EdHolland - 02-23-2018, 07:44 AM
The speaker table error?
Philco 70 antenna lead
