Philco 16B & 116B instruction pamphlet
Thanks Jeff. I already found the 116X pamphlet and the 16B code 125 sheet. Just nothing specific on on the two I mentioned. A first hunt on the internet turned up nothing. I will keep looking though. If it find them, I will post and share them.
RE: Philco 16B & 116B instruction pamphlet - by Scott D - 02-06-2018, 11:33 AM
There are currently 9965 online users. [Complete List]
» 1 Member(s) | 9964 Guest(s)
