Picture of AK 944 Chassis Underside
It also has a surprising large speaker, about 8". However this speaker has the front-mounted spider (metal lattice with a screw in the middle in front of the pole piece. This probably reduces the effective range in both vol and frequency possibly making the smaller Philco speaker sound better.
RE: Picture of AK 944 Chassis Underside - by Phlogiston - 02-06-2018, 12:41 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2607 online users. [Complete List]
» 3 Member(s) | 2604 Guest(s)
