Restoration info
All you have to do is use the Wayback Machine.
http://archive.org/web/web.php
In the box to the right of the Wayback Machine logo near the top of the page (the box already has http:// in it), just type in philcorepairbench.com and click the Browse History button.
You will be presented with a timeline. Any date from 2016 on back should work for you.
We have some bakelite block info here. Look:
http://www.philcoradio.com/phorum/showth...?tid=14964
and resistors:
http://www.philcoradio.com/phorum/showth...?tid=14966
Restoration info - by 45philcodon - 02-06-2018, 06:52 PM
RE: Restoration info - by Ron Ramirez - 02-06-2018, 07:25 PM
RE: Restoration info - by Nathan Slingerland - 02-06-2018, 07:25 PM
RE: Restoration info - by Ron Ramirez - 02-06-2018, 07:31 PM
RE: Restoration info - by Nathan Slingerland - 02-06-2018, 07:36 PM
RE: Restoration info - by 45philcodon - 02-06-2018, 07:48 PM
RE: Restoration info - by Kenneth F. Besso Jr. - 02-06-2018, 08:44 PM
The speaker table error?
Philco 70 antenna lead
