Philco 37-60 Hum, Weak Reception
Hello and welcome!
I changed the title of your thread as a title describing the subject at hand is more likely to get more input than a thread with your name as the title. Thanks for understanding.
I think the first question would be, regarding the hum, are you sure you have the electrolytic capacitors' negative terminals connected correctly?
Philco 37-60 Hum, Weak Reception - by bzadel - 02-07-2018, 02:26 PM
RE: Philco 37-60 Hum - by Ron Ramirez - 02-07-2018, 07:04 PM
RE: Philco 37-60 Hum, Weak Reception - by vinzer - 02-07-2018, 11:01 PM
RE: Philco 37-60 Hum, Weak Reception - by bzadel - 02-08-2018, 12:34 AM
RE: Philco 37-60 Hum, Weak Reception - by bzadel - 02-08-2018, 02:20 PM
RE: Philco 37-60 Hum, Weak Reception - by bzadel - 02-08-2018, 02:36 PM
RE: Philco 37-60 Hum, Weak Reception - by bzadel - 02-08-2018, 02:51 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6846 online users. [Complete List]
» 2 Member(s) | 6844 Guest(s)
