Another Philco 89 from H**l
It could be a bad resistor in the oscillator tank circuit as well, I've had sets that would do that, the oscillator would quit working at one end of the AM broadcast band. However I believe that if the primary winding is reading high in DC resistance then corrosion has probably already set in and that winding will require replacement.
Another Philco 89 from H**l - by Ron Ramirez - 10-04-2005, 06:22 PM
RE: Another Philco 89 from H**l - by fenbach - 01-31-2018, 10:50 PM
RE: Another Philco 89 from H**l - by morzh - 01-31-2018, 11:38 PM
RE: Another Philco 89 from H**l - by Radioroslyn - 02-01-2018, 12:59 AM
RE: Another Philco 89 from H**l - by madsowry - 02-09-2018, 01:17 AM
RE: Another Philco 89 from H**l - by Arran - 02-09-2018, 02:29 AM
RE: Another Philco 89 from H**l - by madsowry - 02-09-2018, 03:40 PM
[No subject] - by Ron Ramirez - 10-05-2005, 06:22 PM
[No subject] - by Chuck Schwark - 10-05-2005, 06:57 PM
[No subject] - by Ron Ramirez - 10-06-2005, 01:56 PM
[No subject] - by Chuck Schwark - 10-06-2005, 01:57 PM
[No subject] - by Ron Ramirez - 10-17-2005, 10:18 PM
[No subject] - by Chuck Schwark - 10-27-2005, 09:43 PM
[No subject] - by Ron Ramirez - 11-25-2005, 12:59 AM
The speaker table error?
Philco 70 antenna lead
There are currently 5936 online users. [Complete List]
» 1 Member(s) | 5935 Guest(s)
