Philco 7052 Tube Tester
I appreciate all your help, but unfortunately, they had uploaded the one for the 7050 which is an emissions tester only, instead of a mutual conductance tester which is what the 7052 is.
Thanks, for researching it.
Philco 7052 Tube Tester - by tekky - 02-08-2018, 02:50 AM
RE: Philco 7052 Tube Tester - by KCMike - 02-08-2018, 11:48 AM
RE: Philco 7052 Tube Tester - by klondike98 - 02-08-2018, 12:44 PM
RE: Philco 7052 Tube Tester - by tekky - 02-08-2018, 11:42 PM
RE: Philco 7052 Tube Tester - by tekky - 02-08-2018, 11:44 PM
RE: Philco 7052 Tube Tester - by KCMike - 02-09-2018, 10:50 AM
RE: Philco 7052 Tube Tester - by tekky - 02-09-2018, 01:07 PM
