philco model 84
Most of the hum is gone when the 77 tube in sheild is pulled out of its socket I have tryed 3 77 tubes with no change I changed all off value resisters which was all but one or two. Hum is not to noticeable when tuned to a station.
The service bulitation show a humbucker but I dont see one on the speaker looks orginal speaker.
philco model 84 - by vinzer - 05-02-2010, 04:37 PM
Re: philco model 84 - by 7estatdef - 05-03-2010, 08:56 AM
Re: philco model 84 - by vinzer - 05-03-2010, 06:22 PM
Re: philco model 84 - by Ron Ramirez - 05-03-2010, 08:50 PM
Re: philco model 84 - by vinzer - 05-03-2010, 09:38 PM
Re: philco model 84 - by denver - 05-03-2010, 10:56 PM
Re: philco model 84 - by vinzer - 05-08-2010, 05:14 PM
Re: philco model 84 - by rghines1 - 05-09-2010, 06:08 PM
Re: philco model 84 - by vinzer - 05-09-2010, 09:10 PM
Re: philco model 84 - by Ed Locker - 05-10-2010, 09:01 AM
Re: philco model 84 - by gary rabbitt - 05-11-2010, 11:53 PM
Re: philco model 84 - by vinzer - 05-12-2010, 11:31 AM
Re: philco model 84 - by Chuck Schwark - 05-12-2010, 01:53 PM
Re: philco model 84 - by vinzer - 05-12-2010, 02:28 PM
Re: philco model 84 - by Chuck Schwark - 05-12-2010, 03:07 PM
Re: philco model 84 - by vinzer - 05-12-2010, 04:34 PM
Re: philco model 84 - by vinzer - 05-28-2010, 05:47 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
