model 18 no reception
>I don't know how to measure them for that result
Simple way is to use an analog ohm meter connected to center and one of the end terminal on the volume control. With the meter set for the proper range the needle on the meter should move nice and smooth as you rotate the shaft on the control. If the needle moves erratically it indicates that the carbon track is worn out and will not work properly.
model 18 no reception - by madsowry - 02-02-2018, 12:03 AM
RE: model 18 no reception - by morzh - 02-02-2018, 09:14 AM
RE: model 18 no reception - by Radioroslyn - 02-02-2018, 10:04 AM
RE: model 18 no reception - by madsowry - 02-02-2018, 04:28 PM
RE: model 18 no reception - by morzh - 02-02-2018, 11:16 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 01:59 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 04:30 PM
RE: model 18 no reception - by Radioroslyn - 02-03-2018, 05:52 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 06:54 PM
RE: model 18 no reception - by morzh - 02-03-2018, 07:24 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 07:54 PM
RE: model 18 no reception - by morzh - 02-03-2018, 08:11 PM
RE: model 18 no reception - by madsowry - 02-04-2018, 12:08 AM
RE: model 18 no reception - by morzh - 02-04-2018, 10:51 AM
RE: model 18 no reception - by madsowry - 02-04-2018, 02:08 PM
RE: model 18 no reception - by Radioroslyn - 02-04-2018, 06:17 PM
RE: model 18 no reception - by madsowry - 02-04-2018, 06:34 PM
RE: model 18 no reception - by madsowry - 02-05-2018, 02:50 PM
RE: model 18 no reception - by Radioroslyn - 02-05-2018, 03:53 PM
RE: model 18 no reception - by madsowry - 02-05-2018, 08:11 PM
RE: model 18 no reception - by madsowry - 02-06-2018, 04:51 PM
RE: model 18 no reception - by morzh - 02-06-2018, 08:38 PM
RE: model 18 no reception - by madsowry - 02-07-2018, 12:01 AM
RE: model 18 no reception - by madsowry - 02-09-2018, 06:32 PM
RE: model 18 no reception - by Radioroslyn - 02-09-2018, 08:27 PM
RE: model 18 no reception - by madsowry - 02-09-2018, 09:59 PM
RE: model 18 no reception - by Radioroslyn - 02-10-2018, 10:37 AM
RE: model 18 no reception - by madsowry - 02-12-2018, 12:07 AM
RE: model 18 no reception - by Radioroslyn - 02-12-2018, 09:15 AM
RE: model 18 no reception - by madsowry - 02-23-2018, 01:00 AM
RE: model 18 no reception - by morzh - 02-23-2018, 08:53 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6122 online users. [Complete List]
» 1 Member(s) | 6121 Guest(s)
