Philco 70 volume issue
Hi Wilbur
It's a dual pot on the older model 70's common to have one of the section bad (open). As Bill mentioned a good clean may put it right.
Philco 70 volume issue - by Radiowilbur - 02-10-2018, 11:21 AM
RE: Philco 70 volume issue - by bzadel - 02-10-2018, 01:32 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 01:48 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 01:49 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 01:50 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 02:17 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 03:15 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 04:52 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 05:23 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 07:08 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-10-2018, 08:07 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 08:51 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 08:53 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-10-2018, 10:48 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 10:57 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-11-2018, 12:22 AM
RE: Philco 70 volume issue - by morzh - 02-11-2018, 12:27 AM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 01:21 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-11-2018, 04:30 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 07:25 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 08:23 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-11-2018, 10:38 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6276 online users. [Complete List]
» 1 Member(s) | 6275 Guest(s)
