Philco 70 volume issue
This is a wirewound pot. They don't suffer from dirt as much as carbon ones do.
Do clean it, but then desolder he antenna and check for open both sections.
Philco 70 volume issue - by Radiowilbur - 02-10-2018, 11:21 AM
RE: Philco 70 volume issue - by bzadel - 02-10-2018, 01:32 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 01:48 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 01:49 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 01:50 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 02:17 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 03:15 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 04:52 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 05:23 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 07:08 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-10-2018, 08:07 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 08:51 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 08:53 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-10-2018, 10:48 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 10:57 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-11-2018, 12:22 AM
RE: Philco 70 volume issue - by morzh - 02-11-2018, 12:27 AM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 01:21 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-11-2018, 04:30 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 07:25 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 08:23 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-11-2018, 10:38 PM
The speaker table error?
Philco 70 antenna lead
