Threads: 2
City: Madrid, Spain
Thanks Radioroslyn, this hobby is new for me, any help is much apreciated, never heard about the rule of Ac/DC capacitors, very good information! The gauge of the wires is 20, is used in vintage tube amplifiers, should work fine, and every wire I remove I measure it and cut new one same lenght, and route it same place of the old, but I think some Were changed of place because of the recap, hope not and will work fine. I am starting with the tunning condenser sub assembly to remove it and let me clean and give me more space. The electrolytics are dry but one I removed from the sub assembly is half with liquid, hope this is normal and this not mean has been submerged in water  the mica I have been checking are within value but many resistors not, can I change the watts from 1/2w to 1 or 2w without issues? 1/2w looks very small and "modern" and want to make it as close as possible in my possiblities to original.
RE: Philco 37-610 tombstone restoration - by Jeepeto - 02-10-2018, 02:55 PM
Users browsing this thread: 30 Guest(s)
91H Code 126 Restore
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
There are currently 4882 online users. [Complete List] » 2 Member(s) | 4880 Guest(s)
