Philco 70 volume issue
....i tested both controls with an ohm meter out of the circuit, i even dismantled the back section of the control. each operated smoothly from 0 to their maximum and with correct readings. if you connect to the center pin of either control and measure from either end and then the other, all the readings were smooth and without interruption, glitches or intermittants. zero to 250 and zero to 5K. i believe the control is in good shape. it is a wire wound type and it is clean Philco part by CTS. I think the problem lies elsewhere.
Philco 70 volume issue - by Radiowilbur - 02-10-2018, 11:21 AM
RE: Philco 70 volume issue - by bzadel - 02-10-2018, 01:32 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 01:48 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 01:49 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 01:50 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 02:17 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 03:15 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 04:52 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 05:23 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 07:08 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-10-2018, 08:07 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 08:51 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 08:53 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-10-2018, 10:48 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 10:57 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-11-2018, 12:22 AM
RE: Philco 70 volume issue - by morzh - 02-11-2018, 12:27 AM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 01:21 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-11-2018, 04:30 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 07:25 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 08:23 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-11-2018, 10:38 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6977 online users. [Complete List]
» 2 Member(s) | 6975 Guest(s)
