Model 18 or 118 ?
Sorry Morzh, I thought since the cabinets are identical and also 8 tubes even transformers same part #,that maybe
some other item would be a tip off. If the chassis # won't fly, I'll have to take some pics and post them.
Model 18 or 118 ? - by doug-5er - 02-10-2018, 07:54 PM
RE: Model 18 or 118 ? - by morzh - 02-10-2018, 08:34 PM
RE: Model 18 or 118 ? - by doug-5er - 02-10-2018, 09:01 PM
RE: Model 18 or 118 ? - by Radioroslyn - 02-10-2018, 09:10 PM
RE: Model 18 or 118 ? - by Ron Ramirez - 02-11-2018, 12:29 AM
RE: Model 18 or 118 ? - by doug-5er - 02-11-2018, 07:01 PM
RE: Model 18 or 118 ? - by Radioroslyn - 02-11-2018, 10:46 PM
RE: Model 18 or 118 ? - by doug-5er - 02-11-2018, 11:10 PM
There are currently 5183 online users. [Complete List]
» 5 Member(s) | 5178 Guest(s)
AvatarAvatarAvatarAvatar
