Thanks, all resistors I have new are 1/2w and up, the old ones have a strange color code, philco had own code?
Today I will keep cleaning tunning assembly, I am going to paint chassis after derusting, hope this way will look close to zinc platting and preserve it for future restorers.
Philco 37-610 tombstone restoration - by Jeepeto - 02-09-2018, 08:58 AM
RE: Philco 37-610 tombstone restoration - by Jeepeto - 02-11-2018, 09:50 AM
Users browsing this thread: 18 Guest(s)
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4522 online users. [Complete List]
» 2 Member(s) | 4520 Guest(s)
