Philco 70 volume issue
Radio off, volume at max, I read about 10 ohms from antenna clip to chassis......
Philco 70 volume issue - by Radiowilbur - 02-10-2018, 11:21 AM
RE: Philco 70 volume issue - by bzadel - 02-10-2018, 01:32 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 01:48 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 01:49 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 01:50 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 02:17 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 03:15 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 04:52 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 05:23 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 07:08 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-10-2018, 08:07 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-10-2018, 08:51 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-10-2018, 08:53 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-10-2018, 10:48 PM
RE: Philco 70 volume issue - by morzh - 02-10-2018, 10:57 PM
RE: Philco 70 volume issue - by Ron Ramirez - 02-11-2018, 12:22 AM
RE: Philco 70 volume issue - by morzh - 02-11-2018, 12:27 AM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 01:21 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-11-2018, 04:30 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 07:25 PM
RE: Philco 70 volume issue - by Radiowilbur - 02-11-2018, 08:23 PM
RE: Philco 70 volume issue - by Radioroslyn - 02-11-2018, 10:38 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6144 online users. [Complete List]
» 1 Member(s) | 6143 Guest(s)
