model 18 no reception
I would just change them out especially if they are the older style in the cardboard tubes. Those are from the 70's or earlier. It's cheap insurance plus it can save you some troubleshooting later. Have had sets w/ odd symptoms like noisy audio but all the voltages look good. Rebuild the ecaps and all is good. To be clear these would be later model sets from the 50's and 60's w/twist lock caps.
model 18 no reception - by madsowry - 02-02-2018, 12:03 AM
RE: model 18 no reception - by morzh - 02-02-2018, 09:14 AM
RE: model 18 no reception - by Radioroslyn - 02-02-2018, 10:04 AM
RE: model 18 no reception - by madsowry - 02-02-2018, 04:28 PM
RE: model 18 no reception - by morzh - 02-02-2018, 11:16 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 01:59 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 04:30 PM
RE: model 18 no reception - by Radioroslyn - 02-03-2018, 05:52 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 06:54 PM
RE: model 18 no reception - by morzh - 02-03-2018, 07:24 PM
RE: model 18 no reception - by madsowry - 02-03-2018, 07:54 PM
RE: model 18 no reception - by morzh - 02-03-2018, 08:11 PM
RE: model 18 no reception - by madsowry - 02-04-2018, 12:08 AM
RE: model 18 no reception - by morzh - 02-04-2018, 10:51 AM
RE: model 18 no reception - by madsowry - 02-04-2018, 02:08 PM
RE: model 18 no reception - by Radioroslyn - 02-04-2018, 06:17 PM
RE: model 18 no reception - by madsowry - 02-04-2018, 06:34 PM
RE: model 18 no reception - by madsowry - 02-05-2018, 02:50 PM
RE: model 18 no reception - by Radioroslyn - 02-05-2018, 03:53 PM
RE: model 18 no reception - by madsowry - 02-05-2018, 08:11 PM
RE: model 18 no reception - by madsowry - 02-06-2018, 04:51 PM
RE: model 18 no reception - by morzh - 02-06-2018, 08:38 PM
RE: model 18 no reception - by madsowry - 02-07-2018, 12:01 AM
RE: model 18 no reception - by madsowry - 02-09-2018, 06:32 PM
RE: model 18 no reception - by Radioroslyn - 02-09-2018, 08:27 PM
RE: model 18 no reception - by madsowry - 02-09-2018, 09:59 PM
RE: model 18 no reception - by Radioroslyn - 02-10-2018, 10:37 AM
RE: model 18 no reception - by madsowry - 02-12-2018, 12:07 AM
RE: model 18 no reception - by Radioroslyn - 02-12-2018, 09:15 AM
RE: model 18 no reception - by madsowry - 02-23-2018, 01:00 AM
RE: model 18 no reception - by morzh - 02-23-2018, 08:53 AM
The speaker table error?
Philco 70 antenna lead
