Threads: 2
City: Madrid, Spain
Today I removed the power transformer, I must re insulate all with Heat shrink and glass fiber jacket, the bakelite capacitor have a sprague that looks suspicious, maybe for simulate the twin bakelite? By the way Ron, Thanks for the link, now make sense the resistors
Image(s)
(This post was last modified: 02-12-2018, 05:47 PM by
Jeepeto .)
RE: Philco 37-610 tombstone restoration - by Jeepeto - 02-12-2018, 05:28 PM
91H Code 126 Restore
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM
Philco 70 antenna lead
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM
There are currently 2983 online users. [Complete List ]» 2 Member(s) | 2981 Guest(s)
