Is this usual in Philco sets?
Hi.
I am in the uk and restoring a Philco , the attached images show the circuit diagram and part of the under chassis around the 35Z4GT.
In addition to the Live and Neutral there is a separate mains Earth all emanating from a modern 13 Amp plug.
The Earth wire is soldered to what looks like pin 6 which I think is not used and then via a capacitor to the chassis.
This is not shown in the circuit diagram.
We have been talking about this on our UK Vintage Radio forum but I would appreciate comments from the Philco experts here!
Thank you.
Is this usual in Philco sets? - by JollyRoger - 02-13-2018, 07:41 AM
RE: Is this usual in Philco sets? - by morzh - 02-13-2018, 12:29 PM
RE: Is this usual in Philco sets? - by jcassity - 02-13-2018, 12:30 PM
RE: Is this usual in Philco sets? - by David - 02-13-2018, 07:08 PM
The speaker table error?
Philco 70 antenna lead
