  • 1 Vote(s) - 4 Average
Capacitor type selection
Ceramics don't like RF current. They tend to get hot and change value. Have tried to use them in some of my ham transmitters in the RF amp matching circuit. That could be the same situation that you could have in the hor and ver deflection amps. On the other micas work fine in the RF amps and mylars seem to work fine it the small screen tv's.
N3GTE
Capacitor type selection - by cpollock - 02-13-2018, 06:20 PM
RE: Capacitor type selection - by cpollock - 02-13-2018, 07:32 PM
RE: Capacitor type selection - by Arran - 02-13-2018, 09:55 PM
RE: Capacitor type selection - by Radioroslyn - 02-13-2018, 10:53 PM
RE: Capacitor type selection - by morzh - 02-13-2018, 11:14 PM
RE: Capacitor type selection - by Arran - 02-14-2018, 03:46 AM
RE: Capacitor type selection - by morzh - 02-14-2018, 09:10 AM
RE: Capacitor type selection - by cpollock - 02-14-2018, 01:11 PM
RE: Capacitor type selection - by morzh - 02-14-2018, 04:53 PM
RE: Capacitor type selection - by cpollock - 02-14-2018, 06:14 PM
RE: Capacitor type selection - by morzh - 02-14-2018, 08:13 PM
RE: Capacitor type selection - by Arran - 02-16-2018, 02:01 AM
RE: Capacitor type selection - by morzh - 02-16-2018, 10:27 AM
RE: Capacitor type selection - by WallaceRoger - 02-16-2018, 01:27 PM
RE: Capacitor type selection - by morzh - 02-16-2018, 02:48 PM
RE: Capacitor type selection - by EdHolland - 02-23-2018, 06:56 AM
RE: Capacitor type selection - by David - 02-23-2018, 09:57 PM
RE: Capacitor type selection - by morzh - 02-23-2018, 11:34 PM
RE: Capacitor type selection - by rfeenstra - 02-24-2018, 01:28 AM
RE: Capacitor type selection - by morzh - 02-24-2018, 01:18 PM
RE: Capacitor type selection - by gregb - 02-24-2018, 02:00 PM
RE: Capacitor type selection - by morzh - 02-24-2018, 03:32 PM
RE: Capacitor type selection - by EdHolland - 02-24-2018, 06:06 PM
RE: Capacitor type selection - by NickinMD - 05-28-2018, 12:02 AM
RE: Capacitor type selection - by morzh - 05-28-2018, 10:32 AM
RE: Capacitor type selection - by Ron Ramirez - 05-28-2018, 04:00 PM
RE: Capacitor type selection - by akpual47 - 05-29-2018, 09:39 PM
RE: Capacitor type selection - by morzh - 05-29-2018, 11:11 PM
RE: Capacitor type selection - by brianbbs67 - 06-20-2018, 01:45 AM
RE: Capacitor type selection - by Phlogiston - 06-20-2018, 10:12 AM
RE: Capacitor type selection - by sam - 06-20-2018, 11:11 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 2957 online users. [Complete List]
» 2 Member(s) | 2955 Guest(s)
