Philco 46-350
These are exceptional performers, and if the cabinet is in good shape, attractive as well. I've eliminated the troublesome battery/AC switch and fixed a couple of these sets to run on AC only, eliminated the 117Z3, used a diode and dropper resistor instead to get B+ and filament string well within limits. Be careful so as not to blow out filaments!
Philco 46-350 - by ftovar72 - 10-09-2017, 12:00 AM
RE: [split] Philco 46-350 - by sam - 10-09-2017, 12:24 AM
RE: [split] Philco 46-350 - by Radioroslyn - 10-09-2017, 12:31 AM
RE: Philco 46-350 - by ftovar72 - 10-09-2017, 08:51 PM
RE: Philco 46-350 - by Radioroslyn - 10-09-2017, 10:28 PM
RE: Philco 46-350 - by Raleigh - 10-10-2017, 10:01 AM
RE: Philco 46-350 - by ftovar72 - 10-10-2017, 12:11 PM
RE: Philco 46-350 - by Raleigh - 10-10-2017, 01:18 PM
RE: Philco 46-350 - by ftovar72 - 10-10-2017, 11:55 PM
RE: Philco 46-350 - by Raleigh - 10-11-2017, 09:56 AM
RE: Philco 46-350 - by ftovar72 - 10-12-2017, 06:12 PM
RE: Philco 46-350 - by David - 10-12-2017, 06:50 PM
RE: Philco 46-350 - by ftovar72 - 10-13-2017, 12:01 AM
RE: Philco 46-350 - by Raleigh - 10-14-2017, 08:53 AM
RE: Philco 46-350 - by ftovar72 - 10-14-2017, 08:58 AM
RE: Philco 46-350 - by ftovar72 - 10-18-2017, 10:02 PM
RE: Philco 46-350 - by ftovar72 - 01-08-2018, 12:03 AM
RE: Philco 46-350 - by Radioroslyn - 01-08-2018, 12:40 PM
RE: Philco 46-350 - by ftovar72 - 02-04-2018, 12:56 AM
RE: Philco 46-350 - by ftovar72 - 02-13-2018, 11:06 AM
RE: Philco 46-350 - by codefox1 - 02-14-2018, 04:58 PM
The speaker table error?
Philco 70 antenna lead
